Cutting my erion can
Old Dec 9, 2008 | 09:04 PM
American Psycho 954's Avatar
Default Cutting my erion can
Hey i have an erion slip on......i want to go for a new look, this pipe is way to long. i almost ordered the hr1 exhaust, they sound really good, but i dont know of anyone with one....so now i just want to keep mine n cut it down. Anyone have any tips? is it really that easy? any power losses? im sure its gonna be louder, maybe a little deeper. would i have re-map power commander? thanx,
[IMG]local://upfiles/31871/3A3EE46E491A4601B4C3A7CD298B010F.jpg[/IMG]
Old Dec 9, 2008 | 09:43 PM
skip954's Avatar
Default RE: Cutting my erion can
i wouldn't cut the erion, personally. if you do its real easy with common tools. first make a mark on the can at the length you want. then remove the can. use a "wrap-around" (for pipe work)or a peice of cash register tape, wrap the tape around the can leaving about 3-5 inches on each side. take the two tails and line the sides up together,wiggle a couple times to make sure the paper is straight,then line up one side with your mark. wrap one tail under the other make sure the 2 sides are lined up. this will give you a guarenteed straight line mark for the cut. mark the edge. remove paper cut on line. drill the rivets out of the cap 1/8 in drill bit. set the cap over the cut and redrill the holes in short pipe then re rivit the cap on. enjoy
Mr.Green
Oct 9, 2010 03:42 PM
awood
Dec 31, 2009 02:22 PM
bcouncill
Dec 7, 2008 08:02 AM
dannutz
Mar 19, 2008 01:00 PM
holly
Mar 20, 2006 05:05 AM
