Coolant Leak(small)
Old Aug 25, 2012 | 06:36 PM
FlyWheel's Avatar
Question Coolant Leak(small)
Hi all,
Today I noticed a small amount of coolant under my bike.
I came out give the bike it,s weekly run.
I ran the bike up to temp( 90-100 C)
The fan cut in. that was fine.
Then I looked down and saw a small pool of coolant under the bike. tip of the underneath of the fairing was a small droplet of liquid,so the amount is not huge,but I think still a reason for concern.
I will be taking it back to mechanic I bought it from on Monday.
In the meantime,can anyone add an opinion as to what this may be?
Thanks
Also To add.
I turned bike off and liquid did not drip anymore???
Old Aug 25, 2012 | 07:04 PM
74demon's Avatar
Where was it coming from? If you don't know, put up a pic so we can identify it for you. Then you will know where to start.
Old Aug 25, 2012 | 07:24 PM
FlyWheel's Avatar
ok I will post a pic 2moro,
Thanks
Old Aug 25, 2012 | 09:22 PM
backdoc's Avatar
Check the weep hole on the bottom side of the water pump. If you see fluid there then you have a bad water pump.
stewyF4i
Apr 17, 2014 10:56 PM
awallner
Apr 11, 2013 05:11 PM
wagsjr
Sep 20, 2008 02:31 PM
SReeD08
Apr 20, 2008 12:47 PM
mattyg
Apr 26, 2007 02:58 PM
