Clutch Question
Old May 2, 2006 | 02:40 AM
2QK2C's Avatar
Default Clutch Question
I have a 02 CBR 954RR with almost 15,000 miles, my questions is that recently I have noticed that I have to almost let my clutch lever all the way out before it engages, I know that over time your clutches wear down, but is this a sign that it is close to time to change clutches or is there an adjustment that I can make to correct this.
Thanks.
Old May 2, 2006 | 11:41 AM
matt365's Avatar
Default RE: Clutch Question
Its pretty hard to fry a wet clutch, you just probably need to adjust the cable free play. Try to turn the adjuster **** on the lever, or follow the cable down to the clutch cover & adjust that one. Bring the adjustment in or out depending on where you want your engagement point, but I personally like it when it engages at the end of the lever travel. As long as it's not slipping, then it shouldn't be worn out.
idrivea3
May 9, 2010 12:03 AM
02f4irider
Mar 6, 2009 07:50 PM
lakaiguy
Nov 8, 2008 10:54 AM
SNOWMAN
Feb 6, 2008 03:26 PM
Stray Cat
May 1, 2007 02:21 PM
