Chain & sprocket help
Old Aug 1, 2012 | 05:27 PM
CBRmonst3r's Avatar
Default Chain & sprocket help
I've had my 954 for about 5 months now and my chain is starting to rattle...I've been trying to search for a new chain and sprockest that's good but am coming across a whole bunch of names I don't know....can someone please point me in a direction of a good chain and sprockets thank you
Also is the 520 setup worth it for our bikes?....sorry for the noob questions I'm new to all this
Old Aug 2, 2012 | 01:28 AM
Blues48's Avatar
Do a google search, I'm sure it will turn up a bunch D.I.D., Regina, RKO and on & on.
Old Aug 2, 2012 | 06:25 AM
74demon's Avatar
I like either DID or RK chains, usually in the x ring series. The x rings tend to seal the links better, thus a longer lasting chain. The regular o ring chains are what OEM is, and the work fine too. If your replacing sprockets, get steel. Aluminum ones don't hold up as well
The 520 is lighter than the 530, but is a smaller chain. It will stretch more and wear out sooner, but he weight savings will be more efficient in getting power to the rear wheel. Your call there.
Old Aug 4, 2012 | 10:47 PM
CBRmonst3r's Avatar
Ok cool thanks for the replies....just one more question what are the stock sprocket teeth count and chain link count?
Old Aug 10, 2012 | 05:49 PM
letsride's Avatar
16f -43r 108 links on chain.
Old Aug 10, 2012 | 11:25 PM
CBRmonst3r's Avatar
Thank you letsride
Old Nov 14, 2012 | 10:17 PM
drake5.0's Avatar
i have a 2002 954rr at 60 MPH(96 KPH) the engine is turning 3,800-4,000 RPM's is that normal
Old Nov 20, 2012 | 08:13 AM
Blues48's Avatar
4,000 at 60mph = stock gearing and tire size. Every 1,000 rpm's increase in 6th gear = 15mph more, I've found this to be pretty accurate using my gps.
YunMing
Sep 28, 2013 12:45 PM
Myfirstcbr
Mar 22, 2013 09:40 AM
rider0033
Jul 18, 2008 03:57 PM
bignibb
Sep 9, 2007 10:34 PM
