Chain Question
Old May 17, 2007 | 11:08 AM
richhowerton's Avatar
Default Chain Question
I am about at the end of the life of my Drive chain what is the best one to go with and how hard is it to change? I am very handy when it comes to working on the bike or cars. but do you need a tool to break the locking link ? ? ? ? ?
if this has been out their sorry I did not see it.
Old May 17, 2007 | 11:14 AM
gixxereater's Avatar
Default RE: Chain Question
Do it yourself. A chain breaker is handy......otherwise a torch or cutting wheel works just as good. Grind off the pin heads and it'll pull out or just cut it off. You're replacing the sprockets too right? Yank the old chain off........replace the sprockets.....an impact wrench for the front sprocket will be your friend........put rear tire back on.......install new chain.........the chain tool will come with the parts to pinch the new link on.....or you can use a punch and a hammer (or two.....one on the back side) and punch the pins down.....must make sure you curl them over right or it wont hold.
It's an easy job........have at it.
Old May 17, 2007 | 05:07 PM
joey954rr's Avatar
its an easy job if you have done it before......you can cut the chain off with any thing and install tour own sprockets but i recommend that you let a moto shop put the chain on...it takes a special tool....you can do it with a hammer and nail but if you curl the lip to much the wall of the lip will become to thin and shear off and if you dont curl it enough the link plate will come loose...
Old May 18, 2007 | 01:07 AM
txsmainevent's Avatar
or u could just look for a chain that uses as clip on the masterlink instead of mushroomin the pins. if u cant find a chain that uses that type of masterlink u can find bike shops that sell just masterlinks. ive used both and no matter what other people think that have never used this type of masterlink and tell u how bad of a idea it is ive never had a problem wit it and rode it till it was time to change the chain.
Old May 18, 2007 | 09:35 AM
bobjoezx's Avatar
a solid chain is always the best, i dont use masterlinks, i use the chain tool and make one solid chain, hassle when changing rear tire but i feel safer that the chain is not goin to break or come apart
Old May 18, 2007 | 10:22 AM
What is the best chain and sprocked combo ? ( Maker that is) I am new to this type of bike I have ridded a Goldwing for years and they do not have this kind of power or a chain drive.
Old May 18, 2007 | 12:01 PM
depends on what ur goin for, do you want performance? do you want a more torque low end? get on ebay and search for sprocket/chain combos.vortex is one of the major makers of sprocket/chain components
Old May 18, 2007 | 03:14 PM
Vortex......is good. Renthal has been around for a long time.......Rk.....Regina........AFAM.....all are good.
Do not go with a clip chain........go with an endless chain......your bike and body will thank you when it doesnt come apart.
Go up 3 in the rear from stock and it'll be a good change!!
Old May 21, 2007 | 07:32 PM
joey954rr's Avatar
man i had this ninja that i used the master link on and it used to throw the link all the time...id be riding and all of a sudden it would rev up and i would look back and my chain would be sliding along the street...and to top it off the bike shop that installed it would put it back on and it would happen again...i hated that bike and that bike shop...shop was up in dallas...this was about 4 years ago
Old Jun 13, 2007 | 08:04 AM
machfive's Avatar
I'd go with the D. I. D. chain. If your chain is worn out, chances are so are both sprockets. Now would be a good time to change them too.
killab213
Mar 20, 2010 01:59 PM
Perranomous
Apr 19, 2009 03:04 AM
jrhurst
Feb 21, 2008 11:08 AM
simtech
Jul 7, 2007 12:16 AM
dlbinford
May 19, 2005 09:14 AM
