Can I make my own gasket?
Old Sep 19, 2012 | 12:45 AM
Mattson's Avatar
Hmm, propably better that way, looks fiddly to make a gasket there since there isn't one originally...
Old Sep 19, 2012 | 12:50 AM
bikermerc's Avatar
I agree Mattson. Well I hope I did everything right. I'm kinda worried I'd still get a leak somewhere.
Old Sep 19, 2012 | 04:41 AM
Mattson's Avatar
if the spread of the stuff was even enough, you let it cure for long enough and tighten the bolts in a circular fashion from center to the sides I'd think the possibility is somewhat small, after all the gap between properly tightened parts is almost microscopical...
Old Sep 19, 2012 | 05:08 AM
daviej's Avatar
Listen to these guys bro, why make life difficult for yaself when a small slither of instant gasket will do a much better job.
Old Sep 19, 2012 | 11:11 AM
Conrice's Avatar
just because there is not a gasket, does not mean there is nothing there. even though it's a machine fit surface, generally, there is always some use of engine shellac by the factory. it's not as thick as silicone, but it does do something. using hi - temp (red) silicone is a good idea, especially after you've cleaned off the casing with a razor.
good job, i'm sure that you won't have a leak, and you certainly didn't cause one by using silicone.
Old Sep 20, 2012 | 04:31 AM
bikermerc's Avatar
Well I started the bike up after letting it cure for 24 hours. Had it idle for around 10 minutes and so far so good...the real test would have to be when I give it a short ride. Hope it holds.
kahlilj
Jun 8, 2013 01:36 AM
mrmekon
May 29, 2011 08:50 PM
Shadow
CBR1000F For Sale / Found
Jul 31, 2009 02:00 PM
Sladkixxx
Feb 1, 2009 09:29 PM
