cam chain tensioner removal
Old Jul 24, 2011 | 01:07 PM
Omaha rider's Avatar
Default cam chain tensioner removal
If I take the cam chain tensioner thats on the right side of the motor out, will I have to adjust it when I put it back in the motor? The motor is out of the bike and im taking it in to get a motor mount fixed. The broken mount is located directly below the CCT. Im afriad the gasket on the CCT will melt from the heat from welding and ****. Should I have any worries about removing the CCT? Thanks
02 CBR 954
Old Jul 24, 2011 | 03:20 PM
txsmainevent's Avatar
You should be good if you dont go with an adjustable ape cct.
Old Jul 24, 2011 | 05:50 PM
As you can see from this picture, it is very close the break. Should I remove it?
Also, there seems to be a leak on the very right throttle body insulator. Should I replace the insulator? Maybe it was just loose
Old Jul 24, 2011 | 06:00 PM
Inspect the boots first. Check for cracks or dry rotting. Maybe it was not set on the engine correctly. I really dont see a reason to pull the CCT. There is still quite a bit of distance between that and where it will be welded. The engine gets pretty warm as well.....
Old Jul 24, 2011 | 06:18 PM
Conrice's Avatar
well, its a hydraulic CCT, so once you set it, it'll self adjust. thats if youre pulling it. i wouldn't pull it though, and i really don't think the gasket will melt if you don't pull it.
you can just use some hi-temp silicone gasket maker if you decide to pull it
street600
Feb 3, 2009 12:01 PM
jessej05
Mar 26, 2008 03:30 PM
mossless
May 13, 2007 06:45 PM
hmm
Nov 25, 2006 10:47 PM
ozrider
Feb 7, 2006 02:02 PM
