Best regulator rectifier for 954
Old Jul 4, 2014 | 01:04 AM
letsride's Avatar
Default Best regulator rectifier for 954
Just wondering what is the best regulator/rectifier for my 954.Have never replaced it and bike has 45k.Can I use one from another bike?
Old Jul 4, 2014 | 01:11 AM
TooBroke0029's Avatar
To answer the last part first absolutely, just have to get the correct plug and your ready to roll. But which bike? I have no idea lol I know a common upgrade is to use the gsxr reg but I know some years are terrible. Hope this helps do a quick search and you should be able to find your answer.
Old Jul 4, 2014 | 03:14 AM
mika_u's Avatar
Sept 2014 ROTM
I use Ricks heavy duty and it has worked couple of years whitout any problems. It is attched whit abikos because the plug is very hard to find and the stator plugs wires had taken some damage from the old rectifier that wen't bad. The bigger it is the better. Bigger can dispatch better the heat.
Old Jul 4, 2014 | 08:56 AM
74demon's Avatar
If your reg is like my 929's, its beefy with cooling fins already. These regulators hold up well, which is more than I can say for the stator. 45k on the original unit speaks volumes for how its made.
Stick with the oem part.
Old Apr 14, 2015 | 03:10 AM
sodahyogesh's Avatar
Default What does the black wire do
Hi guys what does the black wire do which is coming out from the rectifier? i have a spare recti from the F4i and it doesn't has the black, can i connect the f4i recti and ground the black wire. Have a look at the diagram, black wire is the left most wire from the rectifier in the diagram.
Attached Thumbnails Best regulator rectifier for 954-9542003wiringdiagrameuropean.jpg
Old Apr 15, 2015 | 03:09 PM
Marco Marfè's Avatar
guy's can ask you a question about the regulator? as we know the left part of the cbr 954 the cover of the regulator it's too much "outside" of the bike and as we already know if you fall from the left part the first part that have damage is the cover of the regulator..exist a regulator (it's just an idea the mine,im asking to you because you know more better than me for sure) exept the hrc,more little to fit on the 954 with a cover like the hrc regulator?
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
shrek
Feb 5, 2008 09:58 AM
jeffrimerman
Dec 22, 2006 03:53 AM
