advise on lifting
Old Jun 28, 2008 | 11:51 PM
gearhead's Avatar
Default RE: advise on lifting
The ratchet strap plus rafter method is awesome. Just find some heavy duty lag hooks from the home depot and locate the rafters under the popcorn.
Old Jul 1, 2008 | 09:03 PM
lptwist's Avatar
ok so i didnt really want to do any type of cutting up my ceiling or anything, so i rigged up a little frame made out of plumbing pipe and it should support the weight of the bike. im hoping this works. i had a friend over and we both weigh about 155 and we both hung on it and it didnt budge. we swung on it and everything to make sure it wouldnt tip over and all that and it seems sturdy so im hoping this works.
[IMG]local://upfiles/26852/4777C56050F2440BAE754775E855FE81.jpg[/IMG]
[IMG]local://upfiles/26852/A84A8883D2734E86AD184878E00413ED.jpg[/IMG]
[IMG]local://upfiles/26852/8DC5DBC7C4C7472C87DFC7B8D09ED995.jpg[/IMG]
Old Jul 1, 2008 | 09:05 PM
lptwist's Avatar
whoops...that was my first time putting a pic in a post...next time i wont put 3 of the same pic in there...lol
Old Jul 1, 2008 | 09:18 PM
Hcstreetriding's Avatar
nice, should work, did you make it so that you could take it apart afterwards and store it easily?
Old Jul 1, 2008 | 10:11 PM
954Andy's Avatar
Looks like a nice little setup you built yourself. It looks like lead plumbing pipe?? If so I would recommend using locktite to help secure the bonds between the pipes. For what its worth I would use as many lifting weights as possible to test the bike lifting station before placing the bike on it. I just wouldn't want to put my 420+ lb bike on a make shift station only tested at 155. But again it looks very nice. And good luck to you.
Just re-read the post and I understand you tested it with 2 155 lb guys. That is a much better test than I originally thought. However I would still Locktite the threads as extra protection. Cheers, and good luck.
Old Jul 2, 2008 | 02:40 PM
lptwist's Avatar
i can take it apart if i had to, but i put alot of sweat into making sure those things were pretty tight, so id rather not. i used pipe tape around the threads to help hold it together, nothing too crazy. if all else fells it would make a good coat hanging rack...lol.
Old Jul 4, 2008 | 12:14 PM
lptwist's Avatar
TADA!! i got it. thanks for all your help and advise.
[IMG]local://upfiles/26852/94776BBDD78D4D978BD2374C865F47D0.jpg[/IMG]
Shueisha
Apr 7, 2012 09:16 PM
Will.Bass
Mar 13, 2011 05:07 PM
Wooster11
May 14, 2009 11:49 AM
jdschmidt
Dec 5, 2008 03:08 AM
waz57
Jun 1, 2006 12:37 AM
