954 rad hose leaking
Hi lads I was changing the coolant because of a leak at the water pump (common problem I believe ) replaced the gasket and o ring and all is fine and dandy except for when I refit the relevant hoses
There was a leak from the small hose that connects to the plastic pipe (the one which connects from the water pump to the reservoir bottle and then to the bottom of the rad left hand side ) anyways I was conscious of not over tightening the hose clip but it still leaked I tightened it a little more then cracked the #^%**! Pipe
Parts are on order but I was wondering if there's a trick to fitting it on to make a perfect seal first time
The hose and pipe were perfect before I removed them I suspect disturbing them caused the problem in the first place I dont fancy cracking it again have any of you guys had this problem
Any help much appreciated
Most water pump leaks are due to the internal seal going bad which cannot be replaced. If you have fluid coming from the weep hole on the bottom of the pump then changing the gasket and o-ring will not fix your leak. I know because I had to change my water pump last year.
What were you using to tighten the clamp? Post a pic of the part that cracked. I don't recall any plastic parts on the pump cover. It should be a small piece of metal pipe that is pressed into the cover that has the smallest hose attached to it.
ya, i had just bought the bike.... i test rode it, really went through it.... it was fine. then when i rode it home (35 miles or so), i noticed the smell of coolant when i put it in the driveway. i loosened the clamps, pulled the hose off, added another clamp, put hose back on, tightened clamps, no more leak. i think i still smelled it for a few short rides, but after that it had sealed...
pretty inexpensive way to see if you can save it
