954 low fuel light
Ainside your gas tank is a small diode called a thermistor. It is basically a temperature driven reisitor. Once the temp of the tank gets so cold, current is decreased and the fuel like turns off. It's a simple fix. Drain gas tank and remove fuel pump assembly. Attached to the assembly is a small can shaped capsules with a single wire attached. Use a soldering gun to remove the solder holding the capsule to the bracket. Open up the capsule and replace thermistor with Look at this on eBay:
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
5 x 1K OHM NTC Thermistor 5mm -
Reassemble and problem solved
Sebastionbear1
The Hurricane Saloon
Feb 19, 2013 01:45 AM
