Is the 954 frame supposed to be hot?
Old 08-21-2005, 12:49 AM
thunderstruck's Avatar
Default Is the 954 frame supposed to be hot?
I just got a 954, and rode it tonight and the frame is just burning hot. The temp gauge was running between 200 and 215 all the time, but I couldnt keep my knees against the frame it was so hot. Ive had alot of sportbikes, but never had a frame be that hot. Is this normal for this bike? If not what could the problem be? Thanks
Old 08-21-2005, 04:06 AM
Default RE: Is the 954 frame supposed to be hot?
mine is always that hot during the day in traffic. at night actually moving like on the highway it runs about 180-185. the frame is usually always hot and if yours is polshed like mine it gets even hotter. one way not to burn your legs is not to wear shorts... I don't burn my legs in jeans
Old 08-21-2005, 10:40 AM
I also got a wake up call from the frame. I was out posing with the shorts on one day. Haven't ridden with shorts again.
Old 08-21-2005, 04:50 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Aluminum frame + hot engine = hot frame Take that puppy to the drag strip and run it 4 or 5 times and feel the frame. I believe you could cook eggs on the thing. Some people theorize that the frame was designed to wick heat away from the engine -- I suppose that could be true but haven't heard it from Honda.
Old 08-22-2005, 01:21 AM
I think it is that the condensor for your frame cooling system is malfunctioning. It is a common problem and should be covered under warranty.
Old 08-22-2005, 02:10 AM
nope there is nothing wrong they all run hot. Mine is a cooker too ever since I got it. Once the fan kicks in it regulates but the frame is still hot. Maybe its a sign that we shouldn't wear shorts but **** it I do..o well
Old 08-22-2005, 10:03 AM
ORIGINAL: longtallsally
I laughed my *** off when I saw that -- thanks
Old 08-22-2005, 09:37 PM
Mama always said...
Old 09-13-2005, 09:55 AM
Mama always said wear your riding gear. I got my bike in Nor-Cal and in winter-spring it never got over 215. I recentally got stationed here in Guam and in the slow *** traffic here and light to light stoping the temp cruses up to around 230 sometimes and holly molly is that frame cooking.
ObsidianOne
08-03-2014 03:40 PM
musantemike
07-13-2009 10:53 AM
musantemike
06-18-2009 02:13 PM
oldZRguy
04-22-2009 09:30 AM
SpecR
05-11-2008 06:51 PM
Quick Reply: Is the 954 frame supposed to be hot?
