2003 CBR954RR Gearbox Problem Help
Old Aug 21, 2011 | 05:21 AM
ozengines's Avatar
Looking at the manual is says:
Page 9-13
Shift drum/shift fork service can be done with engine installed in the frame.
It is in fine print, you can remove the drum, forks and fork shaft.
So we will give it a go.
Thanks for the help annd encouragement guys.
Peter
Old Aug 21, 2011 | 08:21 AM
Bidds's Avatar
Well you get yourself a ratchet and socket and remove the bolts from the oil pan and get it out of the way then you Take the clutch cover and clutch assembly out. Then pull the shift linkage out. Then take the bolts out of the shift drum plate, pull the shift fork shaft out and the shift forks fall out the oil pan. Saves about 10 hours in labor and a few hundred bucks not having to buy gaskets and main bolts. I feel bad you split yours to service the shift forks, i had to replace 2nd gear and the lock washers that hold it in place on mine and its a s#!tty job.
Old Aug 21, 2011 | 09:24 AM
graysonwittwer's Avatar
Crap, wish I would have known that. I had new tranny gears I wanted to put in anyway. And it was a good experience tearing my bike down to nothing and then rebuilding it
Old Aug 21, 2011 | 10:37 PM
Bidds's Avatar
Yeah its not that bad of a job other than time consuming and expensive. Just wish they had a cassette style trans.
Old Aug 22, 2011 | 07:21 AM
Yeah its really not that hard, but definitely isn't as easy as tearing one of my cruisers down!! Lol
MattBorg
Jun 18, 2013 06:01 AM
ozengines
Sep 19, 2011 03:51 PM
xcessivemotosports
Mar 25, 2008 12:28 AM
