2002-2003 954
Old Feb 25, 2011 | 06:24 PM
dusterdude's Avatar
Default 2002-2003 954
i may be picking up a 954 engine that does not have the throttle bodies,is there a set of carbs that will bolt right up to the head without too much bs?thanks
Old Feb 25, 2011 | 09:30 PM
txsmainevent's Avatar
carbs? are you serious???? WHY??? Ebay a set of TBs, once you go Fuel Injected you never go back to carbs.....
Old Feb 26, 2011 | 07:06 AM
dusterdude's Avatar
i reckon im old school,ill look into tb`s and see how it goes
Old Feb 26, 2011 | 10:20 AM
moosestang's Avatar
Because it's cheaper. He'll need the ecm and wiring harness for fuel injections.
Old Feb 26, 2011 | 03:03 PM
dusterdude's Avatar
that was the original idea,to save money,but after searching ebay,the computer isnt too expensive and the tb`s are rather cheap too.unless im missing something.the carb idea is still possible tho,so any ideas on those is appreciated
Old Feb 26, 2011 | 06:14 PM
Ok maybe i got a little confused here. Are you trying to do a motorswap on your f3? I didnt mean to come off like a dick.....
Old Feb 26, 2011 | 06:19 PM
dusterdude's Avatar
no sweat dude,we`re good.im going to put it in a drag frame i have and since i know jack about fi,i figure carbs would be easier to deal with.
Old Feb 26, 2011 | 07:31 PM
TBs=all electronics, carbs-manual
Old Feb 26, 2011 | 08:09 PM
dusterdude's Avatar
xactly
Old Feb 27, 2011 | 07:37 PM
backdoc's Avatar
I would buy all the electronics to run the motor as it was designed. Staying with the fuel-injection setup will allow more fine tuning with a Power Commander and give you more power than the carb setup. Plus you can add ignition modules and quickshifters to the Power Commander.
I like to drag race and just added the quickshifter to my 954 which will allow me full throttle clutchless upshifts at the drag strip. I am guessing this will gain a few tenths off my times due to not having to let off the throttle just a little to shift.
