02 cbr 954 tip over switch fluid inside
Old Nov 25, 2017 | 08:10 PM
Hollywood954305's Avatar
Default 02 cbr 954 tip over switch fluid inside
hi does anyone one know if there's supposed to be fluid in a tip over switch or has water found it's way inside. I find it hard to believe water could get inside as well as its sealed . I would think it would almost have to be submerged.
Old Nov 25, 2017 | 08:19 PM
74demon's Avatar
Yes, there's fluid in there.
Old Nov 26, 2017 | 01:05 AM
There is ok thank you I really appreciate it.
Old Nov 26, 2017 | 02:50 PM
Englishbandit's Avatar
New Member
Yes fluid is meant to be inside
Old Nov 26, 2017 | 10:31 PM
Well I'm having some trouble with my 02 cbr 954 I was riding it stopped at a buddy's for a few then went to start it when I was leaving and the fuel pump won't kick on. I recently replaced the ignition so I thought maybe the diode so I had a few at my shop so I replaced it and still no fuel pump or spark . I checked tip over switch , disconnected kick stand wires and Hooked them together and disconnected them and tried not knowing how that system worked . I swapped out my relays to check them and nothing I also took apart my kill switch and found a black wire and black and white wire bike won't turn over without the two making contact. It I'm not sure what to do to test kill switch being those two need to make contact to turn over starter and thoughts or ideas would be much apreactied
Old Nov 27, 2017 | 01:53 AM
CaBaRet's Avatar
Hi , just take off the kill switch clean it out on contacts, smear with dielectric grease and test, always a good idea to just use the key to turn off and not the kill switch, when at run should be 12v in and 12v out
Old Nov 27, 2017 | 03:54 PM
Thanks for the info .Well I have 12 volts going in and going out so I can't think of much more other then maybe ecu at this point.
Old Nov 27, 2017 | 06:06 PM
CaBaRet's Avatar
Any fault codes come up
Old Nov 27, 2017 | 06:20 PM
I'll look and check again but the only code that ever came up was F1 and it's done that since the day I bought it a few years ago. I'm pretty sure that's all . Thanks
Old Nov 27, 2017 | 07:49 PM
CaBaRet's Avatar
This might help in the fault finding
File Type: pdf
