02 cbr 954 tip over switch fluid inside
hi does anyone one know if there's supposed to be fluid in a tip over switch or has water found it's way inside. I find it hard to believe water could get inside as well as its sealed . I would think it would almost have to be submerged.
Well I'm having some trouble with my 02 cbr 954 I was riding it stopped at a buddy's for a few then went to start it when I was leaving and the fuel pump won't kick on. I recently replaced the ignition so I thought maybe the diode so I had a few at my shop so I replaced it and still no fuel pump or spark . I checked tip over switch , disconnected kick stand wires and Hooked them together and disconnected them and tried not knowing how that system worked . I swapped out my relays to check them and nothing I also took apart my kill switch and found a black wire and black and white wire bike won't turn over without the two making contact. It I'm not sure what to do to test kill switch being those two need to make contact to turn over starter and thoughts or ideas would be much apreactied
Hi , just take off the kill switch clean it out on contacts, smear with dielectric grease and test, always a good idea to just use the key to turn off and not the kill switch, when at run should be 12v in and 12v out
