02 954rr flapper mod????
Old Apr 1, 2006 | 09:31 PM
1fst954rr's Avatar
Default 02 954rr flapper mod????
can i just remove the flapper in the air box??? or do i need to remove all the stuff that goes along with it ?and will i have any problems after i remove it?
Old Apr 2, 2006 | 03:00 AM
matt365's Avatar
Default RE: 02 954rr flapper mod????
Pin it down underneath the intake snorkels. Leave the control cables connected, or you will get a FI warning light.
To be honest, there is no gain for doing it though. It was meant to reduce airbox noise in low-mid revs. The flapper is fully open when at high revs, so there is no airflow increases from taking it out.
I'd say leave it.
Even Dyno runs prove there is no difference.
Old Apr 2, 2006 | 08:26 PM
1fst954rr's Avatar
cool thanks i will leave it alone
Old Apr 2, 2006 | 08:34 PM
NINE2NINE's Avatar
Retired Mod
if you really want to see what it is like, just unplug the rubber vacuum hose than runs into the side that cause the flap to open and close. this will allow it to stay open at all times. no fi light and it gives you the same effect as removing it. if you don't notice a difference, just plug the hose back in and it's back to stock.
burritoeatinmex
Mar 15, 2011 06:39 AM
riclyd
Jul 8, 2008 12:18 PM
TENNBANSHEE
Aug 22, 2007 08:33 AM
1fst954rr
Apr 1, 2006 06:57 PM
mic4me83
Aug 24, 2005 09:55 PM
