yessss I fixed it
Old Feb 9, 2015 | 08:19 PM
modified4speed's Avatar
Default yessss I fixed it
Finally after much patience I fixed the beast. I was removing the right side slider bolt a few weeks back and well it broke. After debating approach for a while I decided to take my time and drill it out. I used what I had so lets here the list. A handful of useless old drill bits 1 great cutting baby bit and a few diferent along the way. Due to the lack of exact size bits I drilled it out to 13/32 and used a M 10-1.5 Helicoil... I even ended up threading the frame lol because lazu cheap me said no to pullinv the motor. Honestly it took ambition because she had been sitting untill today when I decided to tinker. The pic says a thousand words she is fixed Someday I may upgrade to 13-32 grade 8s and remove the Helicoil but To be honest that may never hahappen. Its time to put some more miles on this thing...
Old Feb 9, 2015 | 10:17 PM
74demon's Avatar
Good job solving that problem. Those can be quite the bitch sometimes.
Is there a gap between the frame and motor?
Old Feb 10, 2015 | 12:51 AM
hawkwind's Avatar
Well done! Always feels good when you've solved a problem and saved a bunch of $$$
Old Feb 10, 2015 | 07:25 AM
Conrice's Avatar
I would go to ace and get a spacer so that you don't bottom the bolt on the frame, but good job on the fix.
Old Feb 10, 2015 | 07:34 PM
Thanks guys. I did notice that gap between the frame and head. I am assuming there was a spacer in there to begin with but dummy PO's loose things like this Ill find something to fit in there...
Old Feb 10, 2015 | 07:51 PM
Conrice's Avatar
There should also be another one between motor and frame, same side, rear of the cylinders.
Gotta love asymmetrical bikes, right?!
EDIT:
I zoomed in, it looks like you have that one.
Old Feb 10, 2015 | 07:59 PM
They is what They is lol. I found a used one on Fleebay for cheap. I cant ride until I get a mirror, Blinkers and re locate the plate anyway. Got a 3fer man I strongly dislike Cops...
Wolzio
Aug 2, 2012 04:30 PM
Aussie Johnno
Jun 11, 2010 08:49 AM
JonBrown
Mar 6, 2008 10:56 PM
Northernfirepower
Apr 24, 2007 03:10 PM
