turn signal lights
Old May 23, 2009 | 04:19 AM
rocflip's Avatar
Default turn signal lights
I just changed my undertail on my 929 with a bestem undertail so I had to re do my wirings then when I got done the turn signal wasn't right because now they are blinking faster. What could have I done wrong or is this normal??
Old May 26, 2009 | 08:03 AM
packdog's Avatar
are they both blinking faster or just one side? if it's just one side, i'd say you've got a wire pair backwards. if it's both sides, are the new lights LEDs? i think LEDs have a tendancy to cause this issue. not really a big deal either way.
Old May 26, 2009 | 01:17 PM
BigMike0147's Avatar
Yeah, if the lights are LED's, then they will blink faster unless they have a resistor in the kit. This is due to the LED's having a lower resistance than the factory bulbs. I just left mine blinking faster. It won't hurt anything.
Old May 26, 2009 | 10:55 PM
rocflip's Avatar
Yes they are LEDs and it does it on both sides. Wouldn't you think that since its blinking faster it would have the tendency to burn faster??
Old May 27, 2009 | 01:31 PM
I think that LED's have a much longer lifespan vs. a normal bulb
Old May 29, 2009 | 10:10 AM
steves11's Avatar
If you don't like the fast blinking use resistors. The lights blink faster because LED's use less power than standard bulbs. Therefore the bike thinks the lights are out because less power is being drawn to them. Resistors and tutorials for how to install them can be found online.
ShotByAdam
Mar 18, 2013 03:26 PM
Repsol929Replica
Feb 26, 2012 01:34 AM
Will1000RR
Nov 3, 2011 11:38 PM
flyoncbr954rr
Aug 3, 2011 12:57 PM
08cbrRR
Aug 15, 2008 08:05 PM
