Testing charging system.
you can get a volt meter start up your bike and hook up the alagator clips to your battery and see how many volts it is charging at. if its not charging at 13+ then check your stator and rectifier
hey thanks! yeaI did that already and it stays at like 10.2 volts. I then rev it up to around 5 grand and it satys the same. Do you know how many volts the stator and or rectifier should be pushing out?
