STUPID ATHLETES
Old Feb 8, 2007 | 01:56 PM
bignibb's Avatar
Permanent ROTM Nominee
Default STUPID ATHLETES
holy multiple same post. every topic I was interested in had a tread hijack by athlete that no one has yet to answer, maybe because no one knows?
well the thing about the milage on the bike!!!!?
it might be possible that the milage on the odometer is not the actual milage on the bike, for a couple hundred bucks and e-bay you can have a low milage 929 again, matter of fact I I have a set of guages on ebay with 0 mile for sale around $200.00
the other thing is that I how are you sure that the bad part was your bikes only issue? granted that that part might be bad but it might not be the culprit it your bike?
have you ordered a replacement for the broken part and fixed that issue?
if you did then the problem should go away if you did and the problem is still then you bigger issues.
either the vavle was open running lean or closed and running rich but I don't know if either would cause your motor to do a **** up on you.
Old Feb 8, 2007 | 07:22 PM
Triax's Avatar
Default RE: STUPID ATHLETES
I'm sure you could really do some damage but i'm not sure of to what extent. You have to think that valve is lifting just as fast as your rpm's are high. Fix the valve and if thats not the problem tear into it more. Unfortunately this is the bad side of buying a used bike.
Old Feb 8, 2007 | 08:15 PM
Tahoe SC's Avatar
what are you talking about? who's 'athlete'?
Old Feb 8, 2007 | 09:24 PM
jeh2324's Avatar
God Question...????
jeh2324's Avatar
Sorry.... GOOD QUESTION....?????
Old Feb 9, 2007 | 03:15 AM
13brsxsrr's Avatar
ORIGINAL: Tahoe SC
I must be missing the same thing you are cause I don't have clue what he's talking about.
Old Feb 9, 2007 | 01:36 PM
bignibb's Avatar
athlete, is a member that is newer tha I, what I was actually addresing was the fact that he kept posting the same post on different topics that it was completely unrelated. I was under the impression that that would be known as tread hijack but hey I'm new here so who am I to correct someone. lol
TimBucTwo
The Hurricane Saloon
26
Nov 2, 2013 08:02 PM
MartiniRossy
Jun 11, 2009 02:42 PM
griff4444
Oct 2, 2008 05:03 PM
dwschultzy
Dec 3, 2007 08:47 AM
adams_CBR600f2
May 22, 2007 03:18 AM
