Stock exhaust + PC
Old Sep 17, 2007 | 04:31 PM
mark5009's Avatar
Default Stock exhaust + PC
I am noticing that the standard ECU map has a number of hesitation spots on partial throttle settings (stock 2001, OEM air cleaner + OEM exhaust).
Does anyone know if a PC will smooth this out? I know that there is a "stock" map, I was just wondering if anyone has actually used it.
TIA
Old Sep 17, 2007 | 04:37 PM
gixxereater's Avatar
Default RE: Stock exhaust + PC
Not on a 929, but on my GSX-R i put one on when it was stock and threw in a "stock pipe, stock air filter" map (not the Stock Suzuki map, it was quite a bit different) (As in not the 000 map) and it made a noticable difference in throttle response and mid range power. I doubt highly that it gained anything on top, but in the 2-7k range it woke it up nicely. I recommend it.
Old Sep 17, 2007 | 05:19 PM
mark5009's Avatar
Thanks, GE. I figure that the stock map, not the null map, might do something like that: better fuelling and remove the emissions soft spots.
Old Sep 18, 2007 | 03:22 PM
You got it.......that's exactly what it did. Richen it in the middle at say 10-30% throttle and lean it out on top at 100% where it runs rich to keep it cool from running lean in the middle. Much better.
Old Sep 26, 2007 | 12:36 AM
mark5009's Avatar
So I got an old PCII via eBay and installed it today. Wow! What a difference on partial throttle. Much smoother idle and through the lower part of the rev range. Yet to try it out in the top third. More later.
mosso23
Aug 31, 2009 08:48 AM
Uniqsol
May 18, 2009 12:25 AM
whiteflash
Feb 4, 2009 07:49 PM
stunter411
Mar 22, 2008 04:26 PM
