Speedo Question
Old Jan 17, 2007 | 04:50 PM
929pimp's Avatar
Default Speedo Question
My speedo doesnt work?? Mileage and clock work but how come the speedometer doesnt work and how do i fix it??
Old Jan 17, 2007 | 06:42 PM
crazy900rr's Avatar
Default RE: Speedo Question
find a friend with a 929 and swap out the instruments. if his works on your bike you've isolated the problem. Once you get into instrument problems it gets costly
Old Jan 29, 2007 | 03:23 AM
45th 929 guy's Avatar
does it come on for even a second when you like first start it?
Old Jan 29, 2007 | 06:51 PM
929pimp's Avatar
The gauges are always on, its just the speedo wont tell me how fast i am going.
Old Jan 30, 2007 | 06:49 PM
bignibb's Avatar
Permanent ROTM Nominee
did you check the connection of the cable to your speedo that could be a possible solution?
another this is (shameless self promotion there is a uses set on ebay that's currently around $100 bucks and they have 32k miles on them? I know they work because I own them.
if you find out that it is a guage issue and you will need a new one, I have a brand new 0 miles set never used. never installed if your interested?
they will go on ebay in a couple days but I wanted to give the forum first dibs.
Old Jan 30, 2007 | 06:56 PM
Illushun's Avatar
ORIGINAL: bignibb
SHAMELESS. hehehe. lol.
Old Jan 31, 2007 | 03:52 PM
929pimp's Avatar
hmmm how much you looking to get for it?
Old Jan 31, 2007 | 07:42 PM
bignibb's Avatar
well I don't wanna jack this guys tread so ill continue on with possible solutions
the other is that this type of speedo is cam sensor or some type that is non-mechanical so it could be possible that something is interupting the signal
about how much I'd want for the guages?
well the set with the 32k miles on it sold today for $306.00 on ebay so to be honest I'd want at least that, its still less than what honda or other parts place would charge.
let me know if there are any takers because they will be on ebay by monday?
Old Jan 31, 2007 | 08:55 PM
sixs929's Avatar
Back to troubleshooting for a minute - If you're sure the odometer is working, that looks like the main clue that it's a problem with the instument cluster. The speed sensor only sends one signal, if I'm reading the print right - and the signal also goes to the ECM, but the ECM can't interrupt it. So that's telling me the sensor and wiring are probably good.
Old Jan 31, 2007 | 10:21 PM
bignibb's Avatar
sounds like someone might be in the market for a set of guages.......................
I have a set of guages................
1+1=? lol
Cavscout73
Mar 27, 2012 10:01 AM
1down_5up
Jul 2, 2010 05:46 PM
markbarber
Apr 15, 2009 01:20 PM
causeofim
Sep 3, 2007 08:33 AM
TennesseeCBRF2
May 21, 2007 10:44 AM
