new 01 929rr owner need help
Old Jul 22, 2010 | 12:54 PM
lynn pressler's Avatar
Unhappy new 01 929rr owner need help
i just bought a 2001 929rr it is wrecked. I guess the guy had to lay it down and it slid in to the ditch rear wheel first and the force of the rear tire broke the lower case in two spots one of the cracks is clear through and the others are not is it possiable to have the cracks fixed if so would it be safe enough for a begner to ride or should i just find a new case or at least the lower half?
thanx for any advise or help u may give
if u have a 929rr engine case or complete engine and want to sell it call me ASAP 1-(260)-229-9379
or if u think u can weld it for me call also will have pics in a few days
thank you so much
the newest 929 guy
Old Jul 23, 2010 | 10:17 AM
Robles929's Avatar
welds are a bad idea. it will compromise entire case.
get a new case/engine if you can or part that ****er out.
Old Aug 2, 2010 | 11:56 AM
vwmaniacvr6's Avatar
Mine is welded in two places. One is the tab to the frame on the mid right side, and it's welded where the large bolt goes through the swingarm mount. Not the huge bolt for the arm, but the skinnier one for the mount. You need to find a welder that is proficient in welding cast aluminum. It's a rare skill, but they are out there. I've put 13,000 miles on my bike since then, and the bike has been through 3 cycles of 20F Michigan winters followed up with 98F summer temps. No cracks in the weld and it's holding great. But I can't stress enough that like Robles929 mentioned, the case is structural, so if your welder can't do cast aluminum properly don't do it.
HondaRRJunkie
May 8, 2010 05:29 PM
nrecore0223
Feb 23, 2010 11:31 AM
Mighty Kentor
Jan 17, 2010 08:55 PM
hellboytt
Jan 12, 2008 06:31 PM
