mysterious problem, all the oil drained immediately? smoke?
What was the point of doing that? Who does that?
New stator is on its way, as is a shifter rod seal-it appears to be the culprit (the point of oil drip page)
Sub, the fairing didn't touch the curb, and immediately was literally under 3 seconds. What is the sump?
Where the oil pools when the bike is off. The engine oil drain plug is in the bottom of the sump.
Cheers, SB
Can you please post some pictures of it? I can't believe that there's a ton of oil pressure that hits right there where the seal is and causes most of the oil to drain out when it fails. I could see some oil - but you said most of it if not all of it came out, right?
midwestminibikes
Mar 21, 2008 05:52 PM
