lighting problem...
Old Mar 27, 2009 | 01:42 PM
zoniebutt's Avatar
Default lighting problem...
Just picked up a 29, was working fine...
NOW
the 3 headlight bulbs stay on, turn signals wont work, and cluster lights up only when starting up once its cranked on it stops lighting up..... brake light works.....
Old Mar 27, 2009 | 04:12 PM
bukwld360's Avatar
check all the wiring.. probably a short in the system.. if I'm correct turn signals and cluster are on the same wiring pattern.. download a manual with a wiring diargarm and trace. it may be hard but better than paying a shop..
more than likely a grounded wire at the turn signals on in the harness for the cluster.
Old Mar 28, 2009 | 12:32 AM
hellboytt's Avatar
had a similar problem on my 929, turned out the turn signal switch was messed up, take it apart and make sure 3 wires inside still intact, I had to solder mine and it fixed the problem.
Old Mar 30, 2009 | 07:56 AM
packdog's Avatar
It's crappy resolution, but it's all i've got... if someone has a better copy please post!
RReid900
Sep 22, 2010 12:56 PM
Sku110ne
Mar 18, 2009 10:21 AM
avas_dad
Jul 27, 2007 10:14 AM
OLDBIKE
Jan 31, 2007 11:39 PM
louieburns
Jun 13, 2006 03:58 AM
