knocking noise above 3k??
Old Jul 4, 2008 | 12:11 PM
01929er's Avatar
Default knocking noise above 3k??
anyone have any idea what would cause this... i romped on it from 0-140 then slowed back down and came to a light...after i took off at the light when it would go past 3k it would start making a knocking noise...oil level is fine and the oil only has probably 300 miles on it.
Bike has just a touch over 20,000 miles on it
Cant hear it under nuetral revving, must be under a load..it gets so loud im scared to take it past 6k rpms...sounds like its coming from the head??
Old Jul 4, 2008 | 03:14 PM
petrorr's Avatar
Default RE: knocking noise above 3k??
sounds like your bottom half is going south....I got a post somewhere in this forum explaining how I know...but I can pretty much guarantee that your crank bearings are shot. drain your oil and look for copper or metal shavings, if get, im right
Old Jul 4, 2008 | 08:56 PM
sc929's Avatar
+1 my first thought was a wrist pin. It isn't pinging right, do you have good high octane fuel in it??
Old Jul 5, 2008 | 04:28 PM
seldon929rr's Avatar
couple differnt things. it could be a cam chain tensioner. the cam chain is on the right side under the tank.
if you listen when wearing a helmet the sound could be "thrown" to a different location.
mine did the same thing and it turned out being a dead spot in the chain.. check that and if any of the links are stiff it will make a "knocking" sound every revolution over the chain.
Old Jul 5, 2008 | 07:46 PM
01929er's Avatar
always run 91 in it and i road it with my helmet off to hear it better... i have heard the cam chain now from 2 different people..and i dont think it would be a rod or anything because it doesnt do it at idle or free rev where i had a race car that spun a bearing and it knocked no matter what rpm or if there was/wasnt a load...just in case though im gonna throw it in a buddies truck and take it up to a shop to get a look over i think
Old Jul 6, 2008 | 12:53 AM
CROMAG's Avatar
Take a peice of garden hose against your ear and press it around the cam chain.... start it cold.. You'll know right there if it's a cam chain tensioner and save yourself some time to source out the noise thereafter. A cam chain tensioner is more like a rattle at idle and gets louder at the begining of throttle... Not to spook you but your issue does not sound like a cam chain tensioner Best of luck either way...
Old Jul 8, 2008 | 08:25 PM
01929er's Avatar
well the local shop said they are 90 percent sure it spun a bearin so next question... i looked up what is needed for a 954 swap and this is what i found, do i really need all of this?
1. 954 motor/throttle bodies/ airbox do i really need the throttlebodies and airbox????2. 954 main wiring harness 3. CDI 4. instrument cluster/ subharness 5. startswitch 6. headlight switch (not sure if they interchange I know the start switch is different) do i need this???
Cash in hand to anyone that has any of this stuff as well
Kellan
May 1, 2012 01:25 AM
RocketMan84
Jun 28, 2010 01:15 PM
pimpax56
Feb 19, 2009 08:06 AM
malaret
Feb 17, 2008 03:40 PM
Triangle
Jul 6, 2007 03:47 PM
