Injectors?
Old Mar 18, 2009 | 03:05 PM
jeh2324's Avatar
Default Injectors?
I got a question/problem...
I'm not a mechanic so here goes...
Just tried to start my 929 after this winter storage. The bike won't start. I changed the plugs, won't start.
I think i have traced it to the injectors (not getting fuel). When I spray or dump a small amount in the chambers it will fire and run until that small amount is gone (few seconds). I pulled the injectors and they don't seem to be spraying when the pump primes. I pulled the injectors out of that long brass looking tube and gas comes out and it is building pressure behind the injectors. The pump is working fine. I know it's highly unlikely that all the injectors have all failed at the same time.
What now?
Thanks.
Old Mar 19, 2009 | 01:35 PM
jeh2324's Avatar
Okay, I'm embarrassed.
It seems I forgot to reconnect my power commander ground.
Old Mar 19, 2009 | 03:54 PM
BigMike0147's Avatar
Don't worry, it happens! I had a dead battery for the first time the other day, and I was FREAKIN OUT!!
Old Mar 20, 2009 | 08:42 PM
anthonygilbert's Avatar
I have a question, problem, I started my 929 and ran like it was only firring a couple cylinders and when I took it for a test drive it had no power. I changed the plugs and nothing happen! Now I got to start but it runs terrible and when I try to rev the throttle it dies. Last summer I had the similar problem so I took it to a shop and they replaced one injecter and installed a power comm. It ran fine for the season but this year after it set for the winter is when this started to happen. I dont know what else to do and apparently the shop didn't either. Its like they put a bandaide on my bike rather then fixing the problem. If anybody has any idea please let me know, I'm ready to ride and I'm fustrated!!
Old Mar 25, 2009 | 02:16 PM
your_mom's Avatar
make sure you have the coil harness plugs in the right order i tuned up my bike and mixed #2 and #3 up and the bike would not idle run or nothing sounded like@ss
LRS122
Jun 16, 2022 10:04 PM
anthonygilbert
Apr 2, 2009 08:15 AM
turbof4i
Sep 10, 2008 08:06 PM
bcw426
May 20, 2007 12:12 PM
