I need help
Old Sep 16, 2019 | 08:37 PM
Chris chigris's Avatar
Default I need help
I have a 2001 cbr 929rr and I have some electrical issues ....
so my bike died completely when I took a 45 mile ride and then back for another 45 mile ride so about 90 miles within 24 hours on hwy
as soon as I got back I got off the hwy and first stop sign came to a full stop and I lost all power had nothing at all .
now I get home and take out battery trickle charged it and it fully charged checked it with a multimeter it reads 12.60v .
hooked it back to my bike and turned the key for power and still nothing no power at all. So with the battery still hooked up to bike I checked it with the meter and it read only 1.13v took battery out and checked it again with the meter and it read again 12.60v so anyone know what’s wrong
Old Sep 16, 2019 | 11:09 PM
74demon's Avatar
Bad connections???
Old Sep 16, 2019 | 11:24 PM
Originally Posted by 74demon
Bad connections???
But I forgot to mention that I have an older battery and put that in and I did get power and it started my bike but headlight I noticed was not very bright so turned the high beams on and they didn't work bike was still running and low beam was very dim
Old Sep 17, 2019 | 03:01 AM
Jeff Kain's Avatar
Check regulator and stator grounds and fuses start with those.
Old Sep 17, 2019 | 06:45 AM
74demon's Avatar
Well, that changes things a bit.
Check your charging voltage. If it's low, replace the stator and regulator as a set.
Old Sep 23, 2019 | 12:59 PM
Gadgeteer's Avatar
Also sounds like the battery is knackered if it under-performed like that after charging. Probably a secondary effect of a bad charging circuit (or vice versa)
jamesmeader
Dec 30, 2013 12:57 PM
thebuch
Dec 24, 2011 01:22 PM
byarnell
Sep 13, 2010 05:46 PM
NinjaViper
Aug 16, 2010 12:34 PM
SHugo
Oct 24, 2008 06:48 AM
