i have a gearing Question!!!!!!!!!!!!!
Old May 6, 2008 | 05:56 PM
bignibb's Avatar
Permanent ROTM Nominee
Default i have a gearing Question!!!!!!!!!!!!!
ok i have this question about gearing, i was thinking about replacing my chain and sprockest and thought i might up grade my gearing and was thinking about the these posible set ups
15/45
or
17/41
what i want to know for both would be how would acceleration be affected? i.e.
and what draw backs if any would i be looking at
Old May 6, 2008 | 09:33 PM
bravehart's Avatar
Default RE: i have a gearing Question!!!!!!!!!!!!!
i would go 15/45, without going all into it this gearing will really wake the bike up, it'll be a bit more buzzy and mpg will go down a bit depending on how you drive.
17/41 i dont really know what to say..... my guess is it might be harder to take off andaccelleration would bedull,your ride should be smoother and i dont know what to say about mpg, itmight hurt your economy because of the extra power needed to get the bike movingmeans you may be heavy on the gas more often.
Old May 6, 2008 | 10:35 PM
TK954RR's Avatar
Jan 2009 ROTM
go here bro and put in some numbers, may help you out some. http://www.gearingcommander.com/
Old May 6, 2008 | 10:37 PM
NY Erion929's Avatar
I had the 15 T in the front and stock in the back for a while... The acceleration was a big difference without being too aggresive...
Only thing i didnt like was the speedo and odometer were off and clocked xtra miles i didnt really put on... (I know, A speedo healer)
If you put a 17/41 youll probably accerate like a scooter...
Old May 7, 2008 | 10:13 AM
bignibb's Avatar
I used that link for the sprockets but it doesn't tell me about overal acceleration!
Old May 7, 2008 | 11:02 AM
KidCr3nshaw's Avatar
You know how you generally have to get the 9 over 2K RPM's for take-off? Well you might be accused of being a newb to anyone around you with that kit (17/41)...
Vrrrrrrrrrrrrrrrrroooooooooooooo-ummmmmmmmmmmm................
Old May 7, 2008 | 12:33 PM
dagds10's Avatar
What is the stock gearing?
Old May 7, 2008 | 02:41 PM
bignibb's Avatar
16/43
Old May 7, 2008 | 04:42 PM
seldon929rr's Avatar
another thing to consider is when you drop a tooth on the front and add to the rear the chain distance from the swingarm to the bottom of chain increases slightly. if you drop two teeth the chain will be making a sharper break towards the front sprocket and wear faster also putting more strain on your counter shaft. I went -1 in front and +3 in the back and like it
Incognito
Jul 20, 2009 03:05 PM
gerrit5400
Aug 10, 2008 01:15 PM
cbrsixhundredrr
Apr 25, 2008 08:11 PM
SquireSCA
Nov 8, 2006 05:27 PM
nizmo
Apr 12, 2006 11:38 PM
