HELP!!!! How much fork oil do i put into a 929
Old 07-26-2011, 09:40 PM
1 SiCk G's Avatar
Lightbulb HELP!!!! How much fork oil do i put into a 929
How much fork oil does a cbr929 take concidering i dont have the tool stick to measure it i ordered 2 bottles of high performance BELRAY fork oil .
Old 07-26-2011, 10:41 PM
backdoc's Avatar
16.5oz +/- .08oz or 90mm fork oil level. Its easy and cheap to make your own fork oil level tool. Its not recommended to just add fluid and not check the level. Depending on how well you cleaned the forks when they are apart will affect how much fluid it takes to get the correct fluid level. Check out my fork oil level tool I made in the link below.
https://cbrforum.com/forum/how-103/c...lation-120001/
Old 07-26-2011, 11:24 PM
vwmaniacvr6's Avatar
The easy way is to drain each one into a measuring cup and just replace the same amount that came out. Unless you had a leak of course.
FlyWheel
09-18-2012 07:49 PM
driyac
07-11-2010 02:40 AM
WhiteHawk
03-17-2009 10:17 AM
crx2cbr
07-06-2008 01:56 PM
Quick Reply: HELP!!!! How much fork oil do i put into a 929
