HELP HELP HELP HELP HELP
Old Apr 12, 2007 | 04:19 AM
Frozen1's Avatar
Default RE: HELP HELP HELP HELP HELP
To chime in with "sixs929", I replaced my stator at a cost of $300 for the OEM one but I thought it was the Reg/Rec and bought one of those first. Ha Ha...my bike fooled me. It was the stator! Did I mention I replaced the battery too. Oh and you can get a "lower quality" stator for around $150. Hope this helps! I still have a spare Reg/Rec if any one can use one.
Old Apr 13, 2007 | 02:49 AM
01 929For Sale's Avatar
Frozen1, how much do u want for the reg/rec? I had the same problem as u guys a week or so ago and don't have the tools to figure out if its the stator, reg/rec or the battery so I just figured I'd pay the lil bit to get the shop to tell me which it is. I should hear back form them Fri hopefully so if its the reg/rec I'm interested.
Lantern, if you just google something along the lines of "electrical tests regulator stator motorcycle" you'll find some charts and procedures to find out which one is the source of your problem. All you need really is a ohmmeter and a fully charged battery I believe. I just don't have access to those on campus.
Old Apr 13, 2007 | 03:31 AM
QuinC's Avatar
bunch of stators on ebay right now for less then 20$ i had same problem ended up being the stator.. also pull your seat off and the plastic cover underneath it. i had my new stator wire burn up as well. i ended up getting rid of the plugs and solder the wires together and haven't had a problem since.
Old Apr 13, 2007 | 04:17 PM
sixs929's Avatar
Yeah 01 929ForSale's right about the google idea, and it doesn't take fancy equipment, at least in this case. I have the Haynes Manual (as well as the Honda shop manual) and I followed the checkout procedure for the charging system - the stator stood out like a sore thumb just using an ohmmeter. I can run you through the procedure, but it would be better for you (and everybody who owns a 929) to get the Haynes manual - nice clear illustrations and text, with great diagrams.
Old Apr 13, 2007 | 04:29 PM
the greeen lantern's Avatar
ok guys its not my battery,so now im gunna go through all my wiring and try and fix thiis ****
i know **** all about wiring
btw is a clymer manual as good as a haynes
Old Apr 13, 2007 | 06:25 PM
Just found out today that the stator is the problem on mine, hope yours turns out to be a cheaper fix
Old Apr 14, 2007 | 08:37 AM
nope its not
i think ive narrowed it down to the ignitor coil
Old Jul 13, 2007 | 09:19 AM
jtCowboy's Avatar
I was told by a sports bike mechanic that Clymer Manual is better than Haynes. I need to get one.
