Headlight problems plz help
Old Aug 19, 2005 | 02:32 PM
QuinC's Avatar
Default Headlight problems plz help
I was riding last night around 10pm and had my high beams on then turned them off for a car to pass then turned them back on and my head lights went out. the low beam and high beam both would not work. i checked the fuse and its fine. also the middle bulb has a slight orange glow to it, so i dont think its the bulb. i tried unplugging the diffrent lights thinking that at least one of them might work but nothing. i've gone threw all the wiring i could get to without taking off my tank and everything is plugged in. has anyone had any problems like this? or have any idea on what it might be? i checked the manual and all it has is directions for replacing the bulb.
-Cody
Old Aug 20, 2005 | 02:45 PM
BladeRunner's Avatar
Default RE: Headlight problems plz help
QuinC,
Hi. I don't know what your exact problem, but I would check out the headlight switch if I were you. It sounds like the problem didn't happen till you hit the switch. Maybe it's shorting out or something like that. It's worth a shot. Good luck. Later!
Justin
Old Aug 20, 2005 | 03:55 PM
lshybrid195's Avatar
i owuld double check the buld just to make sure they are still fine
Old Aug 20, 2005 | 11:49 PM
QuinC's Avatar
hey thanks for the help guys. but i found the problem.. or my dad found the problem. it was the sub harness where all the wires connect together. the wire going to the headlights burned up kind of and left that nasty rusty electric looking crap on the plug in. so i cleaned it up and now they work fine.
bigboi18184
May 10, 2009 11:08 PM
xmurfx
May 9, 2009 04:03 PM
Ace_f4i
Mar 20, 2008 07:51 AM
cbrrrfan
Aug 25, 2007 10:33 PM
lldreams
Apr 10, 2007 03:48 PM
