fuel pump wont work??
Old Aug 22, 2005 | 11:24 PM
thunderstruck's Avatar
Default fuel pump wont work??
I just got an 01 929 that was wrecked and wasnt running when I bought it. Turn the switch on and the fuel pump doesnt run. I hook the fuel pump directly to battery and it runs, however the bike still wont start even when the fuel pump is running. Whats up with that? Anyway, my first problem is getting the fuel pump to run like normal. All my fuses are good. Is there a pump cutout relay or anything on 929's? I can only find 2 relays under the seat, but those are starter and something else. I dont know what the other one is, but Im pretty sure its not fuel pump. if there is one, where is it located? Im stumped as to what to do, but then again, that doesnt take much. Any advice??
Old Sep 5, 2005 | 02:57 AM
crunchy929's Avatar
Default RE: fuel pump wont work??
There are 2 things i know of for sure that will cause this problem. 1 being the kill switch. I had this problem myself, the solder holding the wires in the killswitch came loose and not only killed the ignition, but the fuel pump also. Also you will want to check the tipover sensor. The tipover sensor is on the frame right by where the subframe mounts in the center bar. You can bypass that with the wires also. But first thing i would check those 2 things. Good luck and hit me up if you have any other things going on, ive been through alot of **** with my 929.
Old Feb 27, 2006 | 01:55 AM
FPGSXR's Avatar
RIP crunchy929.
Old Mar 2, 2006 | 05:34 AM
exx's Avatar
exx
RIP crunchy929.
Precious in the sight of the Lord is the death of His saints. (Psalms 116, Verse 15).
Old Mar 3, 2006 | 03:36 PM
sixs929's Avatar
Also - and this is good advise for everybody - invest a couple of bucks and order Honda's shop manual for the bike. Money well spent.
I went to the stephygee.com/ website and downloaded a free one, and that was cool, but I used about a hundred bucks worth of my boss's toner and paper to print it!
Old Mar 3, 2006 | 05:24 PM
aeroworks's Avatar
freaks me out reading advice from a recently deceased person. but its good some of crunchy929's words will live on to help people.
Old Mar 3, 2006 | 09:43 PM
sixs929's Avatar
Yeah I was reading about him on that Friction Point website - sounded like an OK guy, and plenty knowledgeable about the sport.
Very sad, a damn shame.
RIP crunchy 929
patrick12
May 18, 2020 06:28 PM
C Jacob W
Jul 29, 2013 11:03 AM
vaggabon
Jun 15, 2007 06:12 PM
vaggabon
Jun 15, 2007 08:19 AM
n_vanexel31
Nov 4, 2006 01:37 AM
