Fuel pump hose pressure side broke :( Gas everywhere. Help with AN fittings
Old Nov 5, 2010 | 11:30 PM
turbotransam83's Avatar
Thumbs down Fuel pump hose pressure side broke :( Gas everywhere. Help with AN fittings
So i was putting in my new k&n air filter and had my buddy holding the tank, We tried not to pull on the hose to much got the filter in put the tank back on started the bike and it ran great. I went out about an hour later to go for a ride and noticed a small puddle under the bike. Turns out it was gas, i turned the bike on and the pressure side hose blew a hole through the side and shot gas all over the place.
i can get a stock oem hose from a local shop here for $82 and it will use the stock banjo bolts (which i hate) like stock or i can change the fittings to AN fittings and run braided injection lines for around $50
Id rather get the AN fittings because i plan on turbocharging the bike soon.
Has anyone here had some experence with the AN fittings before? Im kinda confused on what ill need for them. I know i want to get 1 ft of line so i can take the tank off an set it back some to access the airbox and when i go to turbo it to have enough hose to run a booster fuel pump. I think i need -6 AN fittings to metric 12mm 1.5 for the fuel rail fitting and fuel pump fitting but im not sure what else im going to need as far as it goes.
I guess im going to need 4 fittings total and 1 ft of hose. 2 fittings that will screw into 12mm x 1.5 and 2 fittings that will connect to them to the braided hose.
Thanks for any advice.
MegatronousPrime
Apr 29, 2012 09:51 PM
StrikeAnywhere
Feb 25, 2009 09:41 PM
alvareze
Jun 22, 2008 12:03 PM
mrmcchickentrousers
Sep 3, 2007 04:53 PM
Jaybird180
Jul 3, 2007 04:31 PM
