fork seals
my front left fork is leaking and i bought the seals and the brass washers for the drain plugs but i was reading through my manual and it seems like it might not be that bad but i was just wondering if anyone has done it to their bike because they gave it a 4 out of5 on diffucaulty all your feed back would be appriated
I was going to learn abouit replacing inverted seals, but I ended up finding a great deal on aset of new forks so I guess I'm gonna have to put that on hold.
If they're anything like standard forks, should be a simple breeze.
Do one at a time, be mindfull of your parts and pieces and you'll be fine.
ok thats what i figured by reading the manual i just didnt want to get into something i could not finish im pretty micanicly inclined but like i said i didnt want to get in over my head thakns tho
wow yea it thats helps alot it doesnt even look that bad but i dont have a front end jack or holder so now i got to figure how to prop it up do you think i could just prop it up with some 4 by 4s on the frame sliders or bad idea
I'll be a sunofabitch.
I'm gonna hunt those two down last year that tried to argue with me about changing seals on inverted forks... SIMPLER THAN STANDARDS! Hell you don't even have to remove these from the damn triple clamp...
Goldenboy - when I did mine, I wasn't privvy to much in the way of supporting the bike up either. I used and old car tire, couple of 2x4's and a motorcycle stand.
For two people...
Raise the rear wheel, place the tire under the oil pan/exhaust (where it lies under the pan), and start adding boards. Have a buddy lift the front wheel as much as possible to get the other boards in there. Once they're in place let the bike gently onto it. Now, take the stand off the rear and the front should rest right up in the air. Perfect.
Just be mindfull that you don't have the best support in the world and you'll be fine. The most you'll have to torque on anything is the pinch bolts on the upper and lower triple. They don't give much fight - you'll be fine.
When you're done do it all in reverse and take the bitch for a ride!
For two people...
Wouldn't do the sliders thing - just me, I guess. If they were really long then fine but they're so smooth that I wouldn't trust them to not slide around.
Now if they are grooved or something maybe, but I dunno.
ORIGINAL: KidCr3nshaw
For two people...
For two people...
seldon929rr thanks for the video it really helped so i did the job and it took several hours with me and my cousin but it really was not that bad we just take forever to do things but the bushings were bad and the guy at the shop didnt even mention anything about replacing them so i was kinda mad at that i got them on order today and it was super nice the last three days so i was impaitiant to not ride so i threw it back togather and now have to tear it apart again sucks
titleAndStar(329,0,0,false,",")
CBR13F2
Apr 20, 2008 11:16 PM
