FLAPPER Valve issue
Old Jul 28, 2009 | 03:40 PM
Bklynjoker's Avatar
Default FLAPPER Valve issue
I just started reading about this MOD and i've searched my 01 929 and cant seem to find this hoes that needs to be removed and plugged.
I see people posting pics for 1000RR's not havent seen any clear steps for the 929
Can Someone HELP me please... I just want to remove that tube and plug - people are saying it leaves the Flapper open.
Old Jul 28, 2009 | 08:43 PM
929rc51's Avatar
i just put 2 screws in mine to hold it open and removed the cable from the servo
Old Jul 28, 2009 | 08:57 PM
trajiks9's Avatar
Just use 2 zip tie's and you don't even have to remove anything.
Old Jul 29, 2009 | 01:19 AM
Bklynjoker's Avatar
Ok now when lifting the tank do i need to disconnect any tubes connected to tank? I lifted the tank today but saw tubes getting tight as i continued to lift so i just left it alone, dont need gas everywhere?
Old Jul 29, 2009 | 03:07 PM
trajiks9's Avatar
Not necessary to unplug any hoses from the tank. Try to be careful because they will have some tension on them when you tilt the tank. Hook bunge cords through the two front tank bolt holes, and then hook them to the two franken stein bolts located on the tail. This will hold the tank at a 65 degree angle which will allow you to remove the air box. Don't forget to unplug the Air Intake Temp sensor harness (2 philip head screws) in order to completly remove the air box cover.
Old Jul 29, 2009 | 03:22 PM
Bklynjoker's Avatar
Thank you for the replys... wish me luck
pmcg
Oct 6, 2012 07:47 PM
Outlaw 954
Apr 11, 2011 09:22 PM
Dacarius
Jun 9, 2010 02:48 PM
rogfog
Jan 25, 2006 03:24 PM
doncollins
Sep 23, 2005 11:20 PM
