exhaust header install question
Old Nov 21, 2008 | 08:24 AM
packdog's Avatar
Default exhaust header install question
I'm putting things back together and am wondering if there is anything special that should be done to the exhaust header studs on install, for example anti-sieze or locktite? do they get torqued somehow or is it mainly as tight as i can get it without tools then torque the bolt holding the header in place?
Old Nov 21, 2008 | 07:31 PM
bignibb's Avatar
Permanent ROTM Nominee
Default RE: exhaust header install question
every bolt gets torqued down per the service manual but you may be able to get away with tightining everything down good and snug with some locktite
Old Dec 3, 2008 | 01:45 PM
skubysnak's Avatar
Just hand tighten hard with locktite.
Old Dec 3, 2008 | 06:24 PM
jeh2324's Avatar
Torque it till the wrench slips off...
Ha! [:@]
Old Dec 5, 2008 | 10:05 AM
TK954RR's Avatar
Jan 2009 ROTM
What they said
Old Dec 15, 2008 | 03:50 PM
btmlinedan's Avatar
i recenlty put my micron serpant exhaust on and could barely fit the flanges over the exhaust studs. I had to drill the holes out a little bit to get them to fit, and still couldn't get two of the knuts on. I started it up and have a small exhaust leak right off the head, (lucky me) so looks like i'll be taking it back off to re-work on it all over again... :*(
Old Dec 15, 2008 | 06:06 PM
bignibb's Avatar
are you sure you have the right exhaust for your bike and not something else?
Scotty F4i
Sep 17, 2012 02:00 PM
pbn85
May 13, 2010 05:04 PM
packdog
Nov 13, 2008 07:40 PM
makrr
Jun 6, 2007 06:15 PM
SproutRR
May 7, 2007 10:42 AM
