Engine Rebuild Kit
Old 07-28-2012, 07:46 PM
hioc1098's Avatar
Default Engine Rebuild Kit
Does anyone make an engine rebuild kit similar to what you'd find with cars (e.g. everything in one package), or do I have to piece a kit together?
Old 08-09-2012, 09:51 PM
johnnyboy's Avatar
Old 08-09-2012, 11:29 PM
Conrice's Avatar
you'll have to piece it together. really, it depends on how far you're going with a rebuild.
at the minimum, you'll need a head gasket, silicone gasket maker (for stator and clutch), (indian head) engine shellac (for the upper/lower case and oil pan). then you'll need bearings all around. and you cannot forget the stretch bolts (you can't re-use the old ones).
i could go on and on. it depends.
why are you re-building? whats wrong with the motor?
Old 08-10-2012, 06:56 AM
hioc1098's Avatar
I appreciate the info. There's nothing wrong with the engine at this time. When I bought the bike, I had a nice noise. While I was working on it, I started looking at worst case scenarios to research. The noise ended up being a noisy timing chain and valves out of tolerance.
Old 04-20-2013, 02:08 PM
Chefohboy's Avatar
ok so i have a bent valve and seems like i have to rebuild the engine. where can i find valves, pistion rings and other major comppnents?
DTownRunner
01-09-2014 10:03 AM
CSXfan
03-25-2011 09:02 PM
knifemaker87
F2 Tech
09-17-2010 09:21 AM
collector
09-04-2007 03:10 PM
zer0gh0st
04-20-2006 01:18 AM
Quick Reply: Engine Rebuild Kit
