Engine Rebuild Kit
I found this hope it helps:
Cometic Gasket - Engine Case Rebuild Kit- Honda CBR 929RR Fireblade 2000 2001 CBR 954RR Fireblade 2000 2003
http://www.dscbikeshop.com/products/...ITS-HONDA.html
http://www.dscbikeshop.com/products/...120022003.html
you'll have to piece it together. really, it depends on how far you're going with a rebuild.
at the minimum, you'll need a head gasket, silicone gasket maker (for stator and clutch), (indian head) engine shellac (for the upper/lower case and oil pan). then you'll need bearings all around. and you cannot forget the stretch bolts (you can't re-use the old ones).
i could go on and on. it depends.
why are you re-building? whats wrong with the motor?
I appreciate the info. There's nothing wrong with the engine at this time. When I bought the bike, I had a nice noise. While I was working on it, I started looking at worst case scenarios to research. The noise ended up being a noisy timing chain and valves out of tolerance.
