Electrical issue. HELP!
Old Jun 13, 2017 | 03:50 PM
Mitchell Pereira's Avatar
Default Electrical issue. HELP!
So i just bought a 2000cbr 929rr. It ran fine the first few days. One day it just wouldnt start after riding for a couple hours. I turned it off, went into a store and tried starting it and it would go. I replaced tge ground wire to the battery and it was fine. A few hours later it stalled as i was riding. Started up rode to the next stop light, died again and wouldnt start. A few mkns later it started up and was the same cycle of BS all the way home. I realized when i pressed the brakes or the horn it would stall as if it were a killswitch. I then checked the fuses and they were all fine. I left the brake like fuse out and it ran perfectly. I took it for a ride and again, no problem. When i put thw fuse back in, the same things happen. HELP!
Old Jun 13, 2017 | 04:25 PM
74demon's Avatar
Check the wiring for the brake lights. Someone may done a hack job at a repair or mod.
Old Jun 13, 2017 | 04:51 PM
i checked the wires at the brake light and evetything looks fine. I feel like its the main harness shorting out. But again, when i pull the fuse it runs fine. Im so confused...
Old Jun 13, 2017 | 05:25 PM
74demon's Avatar
You need to check more than just at the brake lights. Obviously when that circuit is activated, it's doing something to another system.
j.stursma
Sep 30, 2009 09:48 PM
Shamous
Sep 18, 2009 09:09 PM
ckxtreme
Mar 13, 2009 01:02 PM
3dgar RR
Nov 5, 2008 05:20 PM
sig239
Aug 3, 2008 11:12 PM
