Different Tires for Front and Rear
I know this might be a stupid question, but how bad is it to use two different tires for your front and rear?? I know that having a tread difference could probably cause some problems in wet conditions. What about dry conditions?? Would the compound differences cause problems?? Thanks a lot!
RE: Different Tires for Front and Rear
From what i know you shouldnt notice the difference. While it is usually recomended to have at least matching brands, the only differece i know of beside tread is the side wall height.
EDIT: before the technical junkies jump in, the rubber compund is different too
Well, even though it is not the optimal solution, I used to do this all the time a few bikes ago (FZR600). Never had a problem, even in the rain- however, some of the tires now are designed to work as a pair for water dispersion. I think the Metzeler Sportec M3's are like this, and that's what I have on the 929 now.
Some brands seem to have different general shapes, more pointed, more rounded, so your results may vary if you pick the wrong combination.
Nick
Nick
DevilInDisguise
02-17-2011 04:38 AM
