Coolant flow diagram help
Old Jul 19, 2017 | 10:32 AM
Robl4l86's Avatar
Default Coolant flow diagram help
Hello, I'm Rob and new to the forum. I bought a 2000 929rr in pieces and have managed to replace everything that needed to be and have it running. I'm just having a problem figuring out where one small hose that comes out of the side of the thermostat housing (same side as the temperature sensor connection) is supposed to connect to. I have a manual but that's not helping me. Any advice would be greatly appreciated! Thanks in advance!
Old Jul 19, 2017 | 11:06 AM
74demon's Avatar
It goes to the wax unit on the throttle bodies.
Old Jul 19, 2017 | 11:58 AM
Robl4l86's Avatar
awesome, thanks alot!
Old Jul 19, 2017 | 12:29 PM
Robl4l86's Avatar
I apologize I must have described the wrong hose because there are already two hoses attached to the wax valve. I'm going to load a picture of a different housing outside the bike which may be a better way to explain the hose I'm referring to.
Old Jul 19, 2017 | 04:54 PM
74demon's Avatar
The wax valve should have two hoses on it. The inside one goes to the fitting in the block, and the outer goes to the thermostat housing.
Old Jul 21, 2017 | 03:40 PM
Robl4l86's Avatar
Ok thanks, I got it running but now it misseseems horribly and backfires through the throttle body. Also won't rev up much over 3000 rpm?
Old Jul 21, 2017 | 03:42 PM
Robl4l86's Avatar
I took a video of it but have no idea how to share it on here.
Old Jul 21, 2017 | 03:58 PM
74demon's Avatar
See your other thread
mcastro253
Jul 2, 2012 05:13 PM
jbrogan2007
Mar 18, 2011 04:21 AM
adamw89_2000
Jul 28, 2010 02:17 AM
brnksman30
Sep 26, 2008 12:04 PM
iRIDE
Mar 25, 2008 11:02 PM
