2000 929rr backfire through throttle body, won't rev past 3000 rpm?
Old Jul 21, 2017 | 03:54 PM
Robl4l86's Avatar
Default 2000 929rr backfire through throttle body, won't rev past 3000 rpm?
Just got it running a few days ago and ran fine. Sat for a day or so then wouldn't start because the plugs were fouled (black). Replaced them starts fine but is backfiring at the throttle body and missing terribly and won't rev over 3 or 4000 rpms. Have a video but no clue how to post it. Thanks in advance!
Old Jul 21, 2017 | 03:57 PM
74demon's Avatar
Check your coil wiring. You may have 2 mixed up.
Old Jul 21, 2017 | 04:03 PM
Robl4l86's Avatar
That was exactly it! It's trying to idle at 3000 rpm now?
Old Jul 21, 2017 | 04:07 PM
Robl4l86's Avatar
Nevermind, that stopped once it ran for a minute. Thanks again, I'd be lost without this forum lol!
Old Jul 21, 2017 | 08:01 PM
Robl4l86's Avatar
Keeps fouling the spark plugs (black) is there any way to adjust how rich or lean it's running?
Old Jul 21, 2017 | 09:16 PM
74demon's Avatar
Not without the help of a power commander or something similar.
Stock should not be running that rich, even a bit lean.
Check your FPR for leaking through the vacuum line at pressure.
Did you plug the MAP sensor in?
Old Jul 22, 2017 | 11:23 AM
Robl4l86's Avatar
Yes the MAP sensor is plugged in. Would the MAP being faulty cause it to run rich?
Old Jul 22, 2017 | 11:26 AM
74demon's Avatar
it could, but I don't think it's a high failure item.
Now the FPR is another story....
Old Jul 22, 2017 | 11:37 AM
Robl4l86's Avatar
Ok so more than likely it's the FPR then because there isn't any vacuum leaks anywhere as far as I can tell. Recommendations on where I can get one cheap?
Old Jul 22, 2017 | 12:02 PM
74demon's Avatar
Test it before you buy one. Pull off the vacuum line and prime the pump. If there is any fuel there,its bad.
