I NEED HELP 600F2 fuel flow vacuum hose
Old Sep 25, 2008 | 10:59 PM
brnksman30's Avatar
Default I NEED HELP 600F2 fuel flow vacuum hose
Hi all need some help I have a 92 600f2 seems to run great at lower speeds shifts good great power but if i get up to highway speeds it seems to lag sputter in power a little and the other day it died when I was warming it up acted like it ran out of gas? The fuel valve only has the fuel line on it. The vent? tube(small one on valve) is not hooked to anything..it did start right up after sittin awhile and ran fine again(except on highway)I have read a lot on here everyone says where it hooks up is at a different place? I need to know where to hook up the vacuum valve hose.......I have looked I cant see anywhere on the motor to hook it to. please help....thanks.....
Old Sep 25, 2008 | 11:32 PM
T Berk's Avatar
Default RE: I NEED HELP 600F2 fuel flow vacuum hose
There should be a vacuum hose from the petcock to the cylinder head attached to the #1 intake(left side while sitting on the bike)bellow thecarb insulator(boot).
Old Sep 26, 2008 | 12:04 PM
brnksman30's Avatar
Thanks for the info I have found that someone has removed my valve on the engine at the number one cylinder and replaced with a bolt. I have located a new one at the dealer for about $5. Thanks for the info....
silkyjohhson
Jul 23, 2022 05:42 PM
uhhmoney
Sep 22, 2010 09:28 AM
Malibuskiboats
Nov 19, 2009 09:32 PM
icedime99
Jul 23, 2009 08:44 AM
danny_l_2005
Jan 30, 2008 08:29 AM
