Attn 929 owners: Timing chain noise?
Old 03-01-2010, 03:46 PM
Tony Montana's Avatar
Default Attn 929 owners: Timing chain noise?
Hey guys, just doing my spring maintence on the 929. I have the fairings off and was drying the bike while it was idling and I could hear a mild ticking that is directly related to RPM coming from the left side of the block. Do you all hear the same thing while the bike is running? No strange effects of any sort (smoke, etc.) I figure I'm just hearing the timing chain doing it's job. The bike has 20,000kms on it and runs flawless.
Thanks for the help,
-Tony
Old 03-01-2010, 09:59 PM
nrecore0223's Avatar
In my experience with that noise it is usually the cam chain tensioner. Im a new owner of the 929 but my 600 had that noise and it was extremely common. The factory tensioner is auto adjusting and sometimes it goes out. If you buy an aftermarket one its manually adjustable. If im wrong please someone jump in here.
Old 03-02-2010, 12:22 PM
johnnycrash's Avatar
Your right about the factory tensioner, it has a spring loaded ratchet, and sometimes if it doesnt fully take up the slack the chain will slap a bit..
you can try taking it out and resetting it and see if it goes away. might just be sticking. If you go with a manual tensioner you can set it yourself but you have to check it periodically....
If its just a mild ticking i wouldnt worry too much, but if it turns into a full out slap/clack noise you need to look at it asap.
Grab a copy of the factory manual thats posted at the beginning of this forum, and take a look at how it works, its pretty easy to check it.
I have 2 929's and one has 74k kms on it, and the factory tensioner is working just fine.
Nice bike BTW i have the same exact one, but mines got 24k kms on it..
Attached Thumbnails Attn 929 owners: Timing chain noise?-8916_185212364934_510919934_3763606_1524231_n.jpg   Attn 929 owners: Timing chain noise?-cbr929rr1.jpg
Old 03-03-2010, 07:13 PM
Thanks for the help to all that replied, that is some good information. I downloaded the factory manual (excellent) and took a look. Also had a look at your bikes, the Erion of course is nice and I have not seen a Repsol 929 like that (very nice).
Old 03-03-2010, 07:15 PM
Thumbs up
Thanks for the help!
OZZY_F4
07-22-2022 05:22 AM
tecsterF4
05-08-2011 08:34 PM
TK954RR
08-02-2008 01:17 AM
DarknessHX
01-04-2006 01:54 PM
Quick Reply: Attn 929 owners: Timing chain noise?
