929rr question on the stator? Advice pls
Old Aug 12, 2021 | 09:21 PM
Krl929rr's Avatar
Default 929rr question on the stator? Advice pls
I just replaced the stator and RR and batt like a month ago! Now today I was riding and came to stoplight and I hear this buzzing or whining sound coming from stator cover or in that area but I'm pretty sure it is the stator making the sound because when I rev it up it goes away or if I keep it above 2,000 RPM sitting at idle it goes away or when I go start to accelerate and go through the gears I no longer hear it but it does go away does this mean stator going bad or or what any advice would help thank you
Old Aug 13, 2021 | 06:55 AM
74demon's Avatar
I have my doubts that the stator is making noise as it's a stationary part. Are you sure it's coming from there?
Old Aug 13, 2021 | 08:22 AM
Krl929rr's Avatar
I mean it's sounds like it's coming from there I guess it could be the starter motor but when I wrap it up or give it acceleration about 2,000 RPMs it goes away kind of like if you were just seeing if you're a headlights would get brighter when you rev it up to see if you're statoris charging I guess but just doing that much of a rev it will go away but if I'm sitting there and idle you can definitely tell and hear it and it's coming from inside the standard cover
Old Aug 13, 2021 | 12:41 PM
Krl929rr's Avatar
Hey Damon so I found the issue one of the bolts to announce the stator in the stator cover somehow threaded itself back out or started to at least and when I went to go start it this morning I heard it got off on the middle of the metal sounding so I dropped the stator took it out and that's where I see the head of the one of the mountain bolts and halfway threaded out to slap up so now I have little tiny metal shavings inside of my flywheel area where the stator cover and staters at so how do I go and does that mean now I have metal shavings inside my motor now and throughout my all my oil because as soon as I heard it I cut it off and when I took the stator cover off I noticed you know metal shavings inside of the wheel what should I do about that
Old Aug 13, 2021 | 03:43 PM
74demon's Avatar
That wheel is the rotor that creates the magnetic field with the stator that turns into electricity. A few dings and scratches shouldn't hurt it. You do want to get all the metal out of the engine. Replace the oil for sure, a few times. I'd get a drain plug with a magnet to catch whatever is floating around in there.
Old Aug 22, 2021 | 12:00 AM
A magnetic oil drain plug will help if the bits are ferrous. If they're aluminum or some other alloy, then not so much.
rasta51181
Feb 23, 2011 11:24 PM
DonDDR
Jun 15, 2009 01:30 AM
kennygilliam
Dec 31, 2008 11:02 AM
jvmoak1
Feb 7, 2008 07:29 PM
CoreShot
Aug 29, 2007 05:40 PM
