929 not starting
Old Nov 23, 2009 | 08:27 AM
jim_jams7's Avatar
Red face 929 not starting
I have a 2001 Honda 929 with 29000km on it. Bought it about 6 weeks ago, has been fine until last night, took it for a ride, went into the house, came back out and wouldn't start. Dash still comes on, and fuel pump starts when ignition on, but won't make a sound when trying to start it. Taken battery out, and put on charge, then put back in later, but same deal. Battery looks a bit old. DO you think it could be battery, or something else?
Old Nov 23, 2009 | 03:28 PM
HenryM's Avatar
What checks have you done?
Fuses?
Earth continuity?
Impossible to tell without further info
Old Nov 24, 2009 | 08:31 PM
jamefs912's Avatar
fuses? starter?
Old Nov 25, 2009 | 02:30 AM
jim_jams7's Avatar
I've checked the fuses, they're all fine. I've also tried jump starting it from my car, still nothing. The dash comes on every time when i turn on the ignition, with the clock flashing, but when i press the starter button to start the bike, there is nothing, but the headlights turn off and go back on again when i let go.
Old Nov 25, 2009 | 05:31 PM
jamefs912's Avatar
If the power is cutting off when you try starting it then that means you have a very low battery. If you tried slow charging it and it did not help then most likely is your battery. But also did this happen all of a sudden or did it over time? If all of a sudden then you might need a new stator or more likely a regulator rectifier and it is recommended that these things need to be replaced at the same time. If your don't mind taking chances on buying a battery and maybe ruining it, then I would try that out first, then the R/R, and then the stator. But before you do ALL of this please check ALL your wiring, I know it may be a pain but it's worth it. Would hate for you to spend all this money and found out it was just a grounded wire. Good luck
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
