Woolly Gear Change
Old 09-22-2017, 12:46 PM
Hawkwind2016's Avatar
Hi Guys, back again to update on my progress.
I have disassembled the gear linkage cleaned it all up and re-greased, I've tried every adjustment and while there is some improvement, the top three gears still do not engage with the nice positive action of the lower three.
There is a couple of mm of play in the mechanism, I think in the rose joints. Could this get progressively worse as I go up through the gear box, making 4th, 5th and 6th less positive when they engage?
All the gears work fine, no crunching or anything else unusual.
Old 09-23-2017, 12:20 PM
Hi guys,
Any opinions on the play in the rose joints, could this be causing my gear-shift problems?
I've had a look on line to see if I can find new ones, buy came up zilch. Used ones are available, but who knows if they'll be any better.
Also is there maybe a way to tighten those joints up, so they're not so sloppy?
Cheers guys.
3v1lj03
08-25-2012 07:37 PM
89HurricaneF1
05-07-2012 09:52 PM
mallen83
F2 Tech
08-27-2011 12:17 AM
michealparks
02-10-2010 12:16 PM
otisdr
08-07-2006 06:51 AM
Quick Reply: Woolly Gear Change
