top speed?
Old Jul 10, 2006 | 01:11 AM
  #21
Err's Avatar
Err
Default RE: top speed?
dont' have a speedo so i don't know for sure but i'd guess 170 ish. it was pretty entertaining...
Old Jul 10, 2006 | 01:59 AM
  #22
66droptop's Avatar
I want to take the bike out to Bonneville and see what it'll do with +1 front & stock rear, and about twice the horsepower. I want to be an official 200mph club member.
Old Jul 11, 2006 | 11:56 PM
  #23
gixxereater's Avatar
Hell as long as we're posting indicated speeds by the speedo, Im -1 and bucking a head wind of about 10mph or so, just nudged 181 before shutting down. Surely we all know the 900RR is no good for anything over 170 unless heavily modded. A 929 with more power (supposedly) in 2000 would only manage around 169-171 depending on the magazine you read. I've read on the given day a 93 will push 163 stock, and a 98 will run 166 stock. Those are what I've read, surely they differ a bit given air temp, pressure, altitude, etc. Nobody on this forum is hitting an ACTUAL 180+ with a remotely stock bike. It's a nice thought, but only a thought.
Old Jul 13, 2006 | 08:46 AM
  #24
66droptop's Avatar
ORIGINAL: gixxereater
Regearing it helps a ton. The bike isn't dropped below the powerband for the sake of freeway rpm and saddled witih an unattainable top speed.
Besides gearing, I had a slightly dropped front end, raked back windscreen, loosened mirror brackets so I could fold them flat (they're removed now), flushmounts, exhaust that exited behind my right foot, Uni foam filter, rejeted carbs, free mods.
Old Jul 14, 2006 | 01:47 AM
  #25
DMACK's Avatar
155 still pullin hard, but I ran out of courage.
Old Jul 26, 2006 | 05:10 AM
  #26
del_sol_fen's Avatar
175 with micron full exhaust, K&N air filter, jetted, and -1 front and +2 back sprokets +520chain..........
Old Sep 12, 2006 | 04:10 PM
  #27
ememiya7's Avatar
94' 900rr ... rebuilt carbs, new jet kit, iridium spark plugs from ngk, micron full exhaust, race clutch, cams, mild porting and polish of head, 5,000 miles on new motor. i just got the bike but it was my friends for a little bit after he dumped all this money into it. the other night i wanted to see how fast i could go. my friend was next to me doing 150 mph in my twin turbo rx7 and i blew past him. my tach is dim towards the end but it looked about 170mph if not just a small amount higher. it was pulling a little but i found myself letting off the throttle after looking at the speedometer, it scared the **** out of me not going to lie.
Old Sep 12, 2006 | 10:11 PM
  #28
ducatijay's Avatar
since we're completely lying, i did 210mph.......
are you guys kidding me. a stock cbr is good for 163-167mph.
to go faster you'll need more hp and different gearing. you need to gear it for a lower final drive ratio not a higher one like most of you guys are posting. once you go -1 front and +2 rear it is mathematically impossible to go faster than stock gearing. yeah the bike might be faster on the bottom but you LOSE top speed.
anyway, be honset when posting. my RR on GPS has been clocked at 151mph screaming. 15/45 gearing and 132bhp on a constant rate mustang dyno...............
Old Sep 13, 2006 | 12:25 AM
  #29
MARCOPOLO's Avatar
1999 900 RR I hit my fearometer line of 230kph. Had lots to go but I did not have full gear on and seemed fast enough.
Old Sep 13, 2006 | 04:57 AM
  #30
66droptop's Avatar
ORIGINAL: ducatijay
Negative. Sort of. The stock bike is not gear limited, it is redline limited. Chopping the gearing a bit will, possibly, bump the engine up into the powerband when it matters, say 150mph, rather than the engine lagging below its peak power if it had the stock gearing.
With 15/45, what rpm was 151mph?
